480ELL 4X4 Diesel slow to go and value
Blitzer
12-20-2004 07:37:21
Looking at a 480ELL 4X4 diesel ROPS it seems a little rough. The box scraper is just about worn down to a nub. The loader bucked certianly shows some personality (a litle banged up)The engine has a definate lope or roughness at low idle but smooths out, and runs up on power well.
The part that concerns me is when cold it takes a while till it wants to get moving well. It will creep away and get underway but seems like it need a few minutes of running around before it really drives right. Is that the shuttle trans? Could it be a filter? Or?
Anyone have an idea on values?
Not sure of year model or hours.
agri_con
12-21-2004 04:37:17
 Re: 480ELL 4X4 Diesel slow to go and value in reply to Blitzer, 12-20-2004 07:37:21
These units use a power shuttle?actually a Borg-Warner velvet drive T2112-usually the forward piston return spring wears out -most occasions break causing pack to slip-remove the triangular oil pan after draining alot of debris will be found if this is the case.The units are really inexpensive to rebuild-I use a place in ohio for parts called Northeast components-hope this helps
