Three Point Hitch (Swinging Draft Arms) Model 300
Joe Blahitka
12-19-2004 18:45:05
All the people out there who have restored or who have a Case Model 300 Series Tractor, I would like to know if any of you have 3 point hitch swinging draft arms on them. All these 311's came with Eagle Hitch arms and the swinging draft arms were an option. If you would like to see a picture of them, it is in the Case 300 Series Tractors Parts Catalog R.I. A324 on page 164. I have been looking for another set, but I can't seem to find them anywhere. If anyone knows of where I can find one please let me know. Thanks. Joe
Lincoln
12-20-2004 10:56:08
 Re: Three Point Hitch (Swinging Draft Arms) Model in reply to Joe Blahitka, 12-19-2004 18:45:05
I prefer the eagle hitch over the regular 3 pt arms. I think it is much easier to get implements hooked up. Just my opinion, what do you guys think?
Don Livingston
12-20-2004 06:37:41
 Re: Three Point Hitch (Swinging Draft Arms) in reply to Joe Blahitka, 12-19-2004 18:45:05
I have a 411b with a true 3 pt on it. Sold the lift links off it. The rest is here. Don L.
Joe Blahitka
12-19-2004 20:48:58
JRT: My tractor is a Case 300 Model 311 Roundnose General Purpose not a row crop. When my uncle purchased it, it had the Eagle Hitches on it which he did not like and he asked the Case dealer if they had the three point hitch swinging draft arms. They said yes so he traded in the Eagle Hitch Arms for the three point hitch swinging draft arms. I just purchased another 311 General Purpose for Christmas. It has the Eagle Hitches. I would love to find some three point hitch swinging draft arms for it.
Now I have two Case 300 Model 311 General Purpose tractors. According to Glen, one is a 1956 and one is a 1957. Joe
JRT
12-19-2004 20:06:15
Joe, The 310 round nose, which was a low profile tractor, had the swinging draft arms. I have a 310 and a 311 and the 311 has an eagle hitch. I had a 311 parts tractor with an eagle hitch which I put on the 310 instead of the swinging arms. I like the swinging arms but they were in such bad shape, I replaced them. I have never seen a 311 row crop tractor with swinging arms.
Glenn/Mn
12-19-2004 19:07:52
Pick up a parts book for a 300B series they were the updated version of the 300, may have some comparison parts, good luck finding parts tractors, they usally bring good money. less than 14,500 300 series tractors were made not including the 350 and fiqureing some being stripped for parts over the years and many not ordered with optional equipment, those parts are hard to find.
JGarner
12-20-2004 15:21:19
 Re: Three Point Hitch (Swinging Draft Arms) Model in reply to Glenn/Mn, 12-19-2004 19:07:52
Not to start an all out war here, but you Ford and JD lovers should stick with these tractors to get swinging 3pt arms. Never did like the loosy goosy way they pulled my implements. I didn't like my posthole digger to flop around and my grader blade to move from side to side when dressing our gravel driveway. Give me the rigid eagle hitch with power down like on our 830 and you can plow through the hard pan in adobe soils and be sure your plow is tracking straight behind your SC, etc. If you want swinging arms buy a John Deere.
Joe Blahitka
12-20-2004 17:40:21
 Re: Three Point Hitch (Swinging Draft Arms) Model in reply to JGarner, 12-20-2004 15:21:19
Both systems have their good points and bad points. Yes, the three point hitch system is loosey-goosey but you have to use stablizer bars and then you can use every implement on your farm even if it is not made by Case. With the Eagle Hitch system, it was designed to work with Case implements. Although it can be used with any other implement, you must keep a lot of washers in your toolbox! Also the Eagle Hitch latches were made out of cast iron and if you hit them too hard up against the implement, they have a tendency to break. Today they are not cheap to replace. It's just like the Sony Beta system versus VHS!
JGarner
12-21-2004 13:53:07
 Re: Three Point Hitch (Swinging Draft Arms) Model in reply to Joe Blahitka, 12-20-2004 17:40:21
My dad had his SC from 1953 until he passed away in 1985, never broke a latch and it fit every thing we ever had without adding washers. Same for the 830. You would NEVER see me ditching the original for the other system. I am looking for a tractor right now and my first choice is Case with Eagle hitch due to past experience. Its stronger than plate seel arms, easier to hook up, rigid without adding stabilizers,etc. One man can back up and picks up under implement withpout getting off the tractor, if your are a bit out of alignement either back up or move forward and the arm picks up and latches, but I guess I could never convince you the other way. As far as I am concerned, the Eagle hitch is the best 3pt ever made bar none. If I were to find an SC like I want with the Eagle hitch cut off and ball joints welded on I would either walk away from it or offer much less so I could replace with the real thing.
Like I said, I was likely to start a war of words with other die hards for the other way. Just my opinion and we all know what opinions are worth.
