Case C Carb
Tim Ingles
12-19-2004 10:58:28
Hello. please help!
I have a Case C tractor which even after a carb strip and clean I cannot get enough gas to the engine. The tractor starts first time and has got good,even compression.But,it likes choke all the time. can anyone tell me what number the main jet should be,or pass on any other reason for it's starvation.It has a Zenith carb. Many Thanks and Happy Christmas Tim
jal-SD
12-19-2004 13:25:01
 Re: Case C Carb in reply to Tim Ingles, 12-19-2004 10:58:28
If I remember right, the main adjusting screw has to be out about three turns on ours. I'm sure you've checked, but have you cleaned the passage from the tank into the sediment bulb assembly? Ours likes to collect rust on the top of the outlet where the bulb assembly goes into the tank. Could you have the same problem? (My $0.02 worth. jal-SD)
Tim Ingles
12-19-2004 13:31:01
 Re: Case C Carb in reply to jal-SD, 12-19-2004 13:25:01
jal-SD Thanks for reply, this tractor is running at about3 turns out, I don't thing screwing it out further would have much effect. There is plenty of gas getting to carb. we have rodded it out good!
