Twin control on 580CK testing your hydralic IQ?
johnnydindemingwa
12-18-2004 21:00:07
I have a twin control ( two handles control the boom-swing-dipper-bucket NO FEET CONTROLS)
I am having challenges getting the hang of the controls as I have had a 580B and a 580C both with feet controls and I think more handles.
In looking at the parts book it shows a decal for the hoe controls.It shows if you are facing the rear of the unit, the dipper and bucket are on the left handle, the boom and swing are on the right handle. My unit is just the opposite, the boom is on the left handle. I do not remember for sure , but I think this is the opposite of what my B&C had,(Boom was done by the right hand?) Anyway, not only do I find this confusing, I am concerned that things may be out of balance hydralically. I think I can learn to oppperate this unit the way it is. I would like to know if changing it to the right hand being the boom would be easy? and is there some way to tell if this change was made with hydralic balance in mind? The parts book indicates the valves are different for different opertations, so just changing the hoses, if the valving is correct for the set up I have, would not work? If the hoses were just changed, is it our of balance? Your thoughts on this would be most appreciated.thanks, johnnyd
Bob/Ont
12-21-2004 08:17:07
 Re: Twin control on 580CK testing your hydralic IQ in reply to johnnydindemingwa, 12-18-2004 21:00:07
Johnney, the two common lever setups I have seen are John Deere and Cat or SAE. On both setups the swing is on the LH lever and the bucket is on the RH lever with side to side movement.The Deere setup has the Boom on the LH and the Stick on the RH lever back and forth. Cat is the opposite. If you have a 416 cat the linkages all go directly down to the valve sections when it's set up for JD controls but to set it up for Cat controls there as a pair of bell cranks that connect the Boom control lever on the right to the boom valve on the left and the stick lever on the left to the stick valve on the right as you sit in the operators seat. Look in your parts book for lever and linkage setups for the different patterns.
Later Bob
DKase
12-19-2004 07:21:33
In the industry these controls are called excavator controls. They are standard with all makes. The controls on my #51 JD (I'm sorry but this is my only discrepancy to my Case collection) are the same as you explain yours. I have run about every make of hoe and prefer the 2 handles after I got used to them. I am sure you will to after digging out about 10 tree stumps! LOL DK
Roger (Mi)
12-18-2004 22:36:15
 Re: Twin control on 580B in reply to johnnydindemingwa, 12-18-2004 21:00:07
The 580B with twin controls: The left lever controls the boom lift and the swing. The right lever controls the dipper and bucket. I've operated both systems and prefer the twin controls. Understandbly, one prefers the system that they're accustomed. It would be somewhat difficult to change the positioning of the levers controlling the various functions because each valve has different relief settings. (example: the criss-cross relief in the swing valve) It might be better to try getting more familar with the two lever controls before making changes.
