Identify Tractor
Don Grunewald
12-18-2004 17:57:37
Have purchased a tractor and can`t decide if it is a VAI or a VAO. Serial number tag is missing. It is equipped with a mounted sickle mower. What should I look for?
mjtractr
12-22-2004 08:21:20
 Re: Identify Tractor in reply to Don Grunewald, 12-18-2004 17:57:37
I had one of each, a VAO and a VAI. They are quite different and pretty easy to tell apart. The VAO uses a low mounted seat (you sit on top of and straddle the trans/diff housing)with a short steering column and the gearshift is bent off to the right. The VAI has the same seat and steering column arrangement as a VAC, i.e., you sit high in the seat that is mounted on a flat platform above the housing. VAI's typically have cast iron, disc type rear wheels with 24" rubber.
Alberta Mike
12-19-2004 16:39:23
John mentioned the V series, then went to the VA series in his post. Although the V and VA series looked a lot alike, they were pretty much different tractors for the most part. If it is an overhead valve engine it's a VA, the V series had flathead Continental engines.
John H-WI
12-18-2004 18:23:56
One suggestion, go to the tractor photos and do a search on Case V series and see if you find anything that looks like yours. If it has a mower on it it is more than likely a VAI. Is the 4th gear really fast? Many of the units sold to highway departments had a high speed 4th gear.
