Hoses when taking off hoe?
johnnydindemingwa
12-16-2004 18:12:54
I want to take the hoe off of a 580CK to transport them in two loads. If I take the hoe off completly via the pins what do I do with the hoses both on the tractor and on the hoe. They do not look like they hook back into each other thread wise?? How much does the complete hoe by itself weigh?
thanks johnnyd
johnnydindemingwa
12-16-2004 23:19:18
 Re: Hoses when taking off hoe? in reply to johnnydindemingwa, 12-16-2004 18:12:54
THis response should be credited to Jc marleau, who responded to my email request about this.
I am posting his answer in case anyone else wants the information.
the tractor loader 580CK weighs 6262lbs. diesel and the weight of the tractor loader backhoe is 10,289 so I would say the hoe is approximately 4,027lbs. and unless someone has made modification on the unit your suppose to have only two main hose with fast coupler on both of them that whenever you remove the hoe it is the only two hose you disconnect and the balance of all the hose stay with the hoe. Usually the fast coupler were about underneath close to the axle housing. You just unhook them like any other fast coupler from tractor except those are quite bigger i guess 1-1/4 size. Hope this can help nice talking to you. Jc marleau.
DKase
12-17-2004 10:49:50
 Re: Hoses when taking off hoe? in reply to johnnydindemingwa, 12-16-2004 23:19:18
MAKE SURE YOU CONNECT THE HOSES BACK TO EACHOTHER ON THE TRACTOR OR YOU WILL DEADHEAD THE PUMP WHEN YOU START THE ENGINE!!! Could do serious damage to the pump!
