311 Roundnose motor side panel Clips
C.D. Zook
12-16-2004 13:53:48
We Bought The Replacement sliding motor cover panels and need to find new or replacement clips that attach to the brackets on the hood assembly,for the sliding panel securing pins to lock into and secure the bottom ends of the panels. Any Help/suggestions would be appreciated. Thank You in Advance. CDZ
Joe Blahitka
12-21-2004 06:32:50
 Re: 311 Roundnose motor side panel Clips in reply to C.D. Zook, 12-16-2004 13:53:48
Hi CDZ: I have two 311 Roundnose tractors and I have 5 good clips, 1 broken one and 2 missing! I have been in contact with 2 people who say they might have some, but they have to find them. Still waiting to hear back from them. I will get in touch with them. I assume you need 4. If they have them, send me your email and I will let you know. Joe
C.D. Zook
12-23-2004 05:22:32
 Re: 311 Roundnose motor side panel Clips in reply to Joe Blahitka, 12-21-2004 06:32:50
Good Morning, Joe I Sincerly appreciate your response and I need two of these clips. If you are very lucky and come up with extra clips, I would certainly be happy to buy them from you. Thanks and have a good day! C.D. Zook 6216 S. Hollis Rd. Bartonville IL. 61607 pH. (309) 697-3528
Jim Perry
05-04-2005 05:05:00
 Re: 311 Roundnose motor side panel Clips in reply to C.D. Zook, 12-23-2004 05:22:32
CD, did you get the clips for the side panels?
Roger300
12-17-2004 05:09:02
Hey C.D; I also make those replacement side panels but when the clips are missing from the tractor I haven't found replacements for putting in the panel bracket. I have taken a small piece of stainless steel and and made substitutes to spot weld in there, the wing nut fastener doesn't lock in position but it does hold the panel firmly in place. Use one left on the tractor as a pattern, hope there is at least one. Roger
J CROLEY
04-27-2006 18:36:22
 Re: 311 Roundnose motor side panel Clips in reply to Roger300, 12-17-2004 05:09:02
Hi, I am searching for side panels for a Case 311. Anyone know where I can find them.
Thanks for any help.
