EAGLE HITCH ON VAC ????
KENT
12-16-2004 08:50:14
I JUST PICKED UP A MOSTLY COMPLETE VAC WITH A 3 POINT HITCH AND A GEAR DRIVEN HYDRAULIC PUMP---IF A VAC HAS A 3 POINT, IS IT AN EAGLE HITCH?--I'M NOT INTO CASES, SO I DON'T KNOW MUCH ABOUT THEM---I'LL PROBABLY SELL IT WHOLE OR PART IT OUT---THANKS FOR ANY INFORMATION
Jgarner
12-20-2004 15:34:16
 Re: EAGLE HITCH ON VAC ???? in reply to KENT, 12-16-2004 08:50:14
Where in East Texas? Does it run, smoke, etc.? What"s the serial number? How are the tires? How much are you asking?
KENT
12-20-2004 19:32:13
 Re: EAGLE HITCH ON VAC ???? in reply to Jgarner, 12-20-2004 15:34:16
i'm in palestine--it will take some work to make it run--i listed it on eba*****y auction # 3861774617 after posting question here---my email is open---thanks
JGarner
12-21-2004 14:03:45
 Re: EAGLE HITCH ON VAC ???? in reply to KENT, 12-20-2004 19:32:13
I looked at that one. I'm afraid that I am needing one I can work for a while before tear down for restoration. Also, yours is a little to rich for my blood considering its condition, sorry. Thanks for feeback though.
mj
12-17-2004 08:28:23
What part of the country are you in?
KENT
12-17-2004 08:33:48
 Re: EAGLE HITCH ON VAC ???? in reply to mj, 12-17-2004 08:28:23
EAST TEXAS
dctom
12-16-2004 09:16:07
KEEP IT, YOU WON'T BE SORRY , REAL HANDY LITTLE TRACTOR.
Paul f
12-16-2004 09:01:01
Later VACs came with an eagle hitch (Case's version of the Ferguson 3pt) However over the years many were converted to Ford/Ferguson system. They cut off the end of the draft arms and welded on 3pt Socket/ball setup. The eagle hitch used a latch with a hooked end on the draft arm
Leroy
12-17-2004 17:38:41
 Re: EAGLE HITCH ON VAC ???? in reply to Paul f, 12-16-2004 09:01:01
I am not too familuar with Case but I do know that puting a ball on the end of the Case lift arms instead of the latch system will not work as the front of the arms are mounted so as not to let them swing so as you could not widen them out to get them over the pins. the egal hitch is rigid like if you have stabilizer bars on a Ford or Ferguson
