430 diesel
Ky. Ted
12-15-2004 13:10:41
I just bought a 430 diesel with live power,but you have to push the PTO lever back and hold it so the PTO will work. Was wondering if anyone could tell what i need to do to get it working right. thanks for all who have helped in the past.
Brent Behner
12-16-2004 16:51:40
 Re: 430 diesel in reply to Ky. Ted, 12-15-2004 13:10:41
Ted, Above P.T.O. Shaft There Is A Allen Head Plug. Remove Plug & With A Light & Plyers Turn P.T.O. Shaft & Look For A Button In The Star Washer. Push Button IN With Punch Or Screw Driver & Turn P.T.O. Shaft Counter Clock Wise At Least 3 Notches & Try. Lever Should Be In Foward Position To Adjust, Lever Should Snap In With 20-30 Pounds Of Force. When Done Add HYD. OIL THROUGH Hole To Top Of Hole. BRENT
Ky. Ted
12-17-2004 04:19:10
 Re: 430 diesel in reply to Brent Behner, 12-16-2004 16:51:40
Thanks Brent i will try that Sat. and let you know how it works.
