Case SC Questions
SB in AR
12-15-2004 05:50:39
My father bought a Case SC about a year ago, and it has no serial tag on it. It has the original magneto on it, and is a dual-fuel. (Although the pony tank is missing.) Can someone help me narrow down what year this one was made? Are there any other options/features that will help narrow it down? I know an exact year will be impossible. Thanks in advance.
SB in AR
12-15-2004 07:32:26
 Re: Case SC Questions in reply to SB in AR, 12-15-2004 05:50:39
Is it there AND on the "dash" tag? The others we've got have the serial number on the metal tag on the "dash".
SB in AR
12-16-2004 05:55:28
 Re: Case SC Questions in reply to SB in AR, 12-15-2004 07:32:26
Thanks guys. I love this web site!!
I'll check it out.
C. Amick
12-15-2004 09:27:45
Yes, both places.
jal-SD
12-15-2004 06:18:10
Look carefully on the flange (left side as you are sitting on the tractor) where the motor connects to the rear end. The serial # is stamped there. You will probably have to use a wire brush to get the dirt & paint off, but its been there on every one that I've looked at. Subtract 4 from the first two #'s, that will give you the year, unless it begins with 80, then its a '53 or '54. (My $0.02 worth. jal-SD)
Paul f
12-15-2004 09:46:33
 Re: Case SC Questions in reply to jal-SD, 12-15-2004 06:18:10
to expand on JAL comment if it only has 5 digits stamped on the block flange then it is the 80 series. On my DC the Block is stamped DC25000 but the data plate shows the complete number DC8055000 (Jan 53 build date)
