torque settings 580 ck
Peter Booth
12-14-2004 23:36:44
Hi again all
Could any-one give me the big end, and head bolts settings for my 188D motor please.
I know i should have bought a manual but its a 2 month wait to get one and $350 au dollars and the backhoe will be sold by then.
Peter
Andy Knaebel
12-15-2004 17:07:32
 Re: torque settings 580 ck in reply to Peter Booth, 12-14-2004 23:36:44
The book says: Step 1: torque to 60 ftlbs; Step 2: Grade 8 bolts to 100-115, nuts with hardned washers 95-105, flange nuts 90-100.
For the stuff at the bottom: Connecting Rod Nuts 45-55, main bearing cap bolts 90-100, oil pan (steel type) 10-12, oil pan (cast) 24-28
andy Knaebel
12-15-2004 11:04:36
I am perty sure the head bolts are 90-100 lbs. I have the shop manual and can double check this tonight and get back to you. I am not sure what "big end" is. A little more explaintion and I will see if I can find the setting for this as well.
MickK
12-15-2004 13:30:53
 Re: torque settings 580 ck in reply to andy Knaebel, 12-15-2004 11:04:36
"big end" is typically the big end of the conrod (connecting rod). The one from the crank to the piston.
