580 CK engine parts
Chainsaw
12-14-2004 19:42:42
I have a 1967 580 CK with a 188D. I am restoring it and need some help with getting some parts. I am looking for a crank shaft as mine is cracked. is there a place to get any used motor parts, or is new my only option?
Chainsaw
12-17-2004 09:26:37
 Re: 580 CK engine parts in reply to Chainsaw, 12-14-2004 19:42:42
I found all of the nunbers.
580 CK
Ser# 8324988 I think. The numbers were hard to read.
Engine G188D
Ser# 2636314
Crank casting# G-11740
Hoe# 34
Ser# 4136812
Any info on this machine would be greatly appreciated
JCMarleau
12-14-2004 20:06:10
I do have a crank for your 580CK my e mail is [email protected]
Chainsaw
12-17-2004 09:31:10
 Re: 580 CK engine parts in reply to JCMarleau, 12-14-2004 20:06:10
580 CK
Engine G188D
Ser# 2636314
Hoe# 34
Ser# 4136812
johnnydindemingwa
12-14-2004 20:03:47
what is the tractor serial number as well as your engine serial number?
it is my understanding that the blocks corrode out in some of these units and that replacement blocks are getting harder and harder to find, hence you may find a corroded block that is not useable except for parts like your crank. I ask about ther serial numbers as it will tell more people about what you have and I am trying to identify the year of a unit I am looking at. your serial number will help. How do you know the year? good luck johnnyd
Chainsaw
12-17-2004 09:31:59
 Re: 580 CK engine parts in reply to johnnydindemingwa, 12-14-2004 20:03:47
580 CK
Engine G188D
Ser# 2636314
Hoe# 34
Ser# 4136812
johnnydindemingwa
12-17-2004 11:16:37
 Re: 580 CK engine parts in reply to Chainsaw, 12-17-2004 09:31:59
you might check the hoe model number again. My guess is it is a model 33?
Chainsaw
12-17-2004 16:05:36
 Re: 580 CK engine parts in reply to johnnydindemingwa, 12-17-2004 11:16:37
I double checked and it is a 34. The ser# might not be correct in the last two numbers as it was hard to read.
