430 ALTERNATOR
Scotty in Ky.
12-14-2004 11:40:21
I was wondering what is necessary to put an alternator on a 1963 430 gas tractor.Thanks
Roger (Mi)
12-16-2004 16:05:56
 Re: 430 ALTERNATOR clearance problem in reply to Scotty in Ky., 12-14-2004 11:40:21
When Case started putting alternators on 430,s, they put a slight outward dimple in the sheet metal to make clearance for the increased size of the alternator. Since the Delco alternator is larger than the prestolite, an even larger sheet metal modification would need to be made. It can be done. Just make sure there is a negative ground.
