Case 530 questions
Pesther
12-14-2004 11:04:53
HELLLLP! My husband bought an old Case tractor that suddenly has developed problems. It is a Case 530, Model G530CB. A tractor mechanic is baffled on this one. The carburator and starter has been replaced along with plugs & other things. There is plenty of compression & spark but the tractor will not turn over. Because it is old and there is no manual with it can anyone help us with engine specs like timing, firing order of plugs, the type of transmission fluid and brakes. We do not have internet at home so I'm the go-between. Any help would be greatly appreciated
ken239
12-16-2004 21:16:02
 Re: Case 530 questions in reply to Pesther, 12-14-2004 11:04:53
If you hsve a good carb, compression and spark, I would think your timing has to be off. Rotate the dist around while cranking.
Dennis/Ohio
12-16-2004 08:53:07
You really need to find some manuals. An inexpensive I&T manual C-202 would get you going. I think your questions are too involved for anybody to answer without writting a book.
Best wishes, Dennis..... ....
johnnydindemingwa
12-14-2004 19:57:56
this info is hand written in the front of a 530 gas parts catolog i have.
gap 16 to 19 I think this is for the points
timing 29 degrees BTDC
rear end 90 weight
trans hydralic oil
valves all hot or cold 14
that is all I have I thought the gentlemen on this site would provide a better response to a lady. I do not have a 530 but I see lots of posts about them so my guess is that many of these fine fellows have them and just did not see your post. put it out again with a lady in distress title! I hear those are good old units that are not too hard to fix. good luck!johnnyd
