Paging John Saeli
JDB
12-14-2004 10:30:46
Were you selling new shifter boots for DC'S at one time and are you still?
John Saeli
12-14-2004 10:50:47
 Re: Paging John Saeli in reply to JDB, 12-14-2004 10:30:46
Hey JDB: Yes, I still have them. I also have New, Original style Light & Magneto switches for CASE.
Alberta Mike
12-14-2004 13:54:56
 Re: Paging John Saeli in reply to John Saeli, 12-14-2004 10:50:47
I'm wondering if you might have new shifter boots for the model V Case tractors. I can get you the measurements if you're not sure.
John Saeli
12-14-2004 15:22:07
 Re: Paging John Saeli in reply to Alberta Mike, 12-14-2004 13:54:56
Hey Mike: Are they smaller than the "S" & "D" series boots?
Alberta Mike
12-14-2004 16:07:47
 Re: Paging John Saeli in reply to John Saeli, 12-14-2004 15:22:07
That was easy, most of the snow has melted (we're in a heat wave). This little boot is about 2" in overall height. The top (shift lever shaft) round opening is about 11/16" in diameter. The lower opening is about 2 1/4" in diameter. The lower opening has a bit of a lip moulded into it to grab the shifting platform casting which has a groove cast into it. I have removed the email hide feature from my name link on this message.
John Saeli
12-14-2004 17:32:03
 Re: Paging John Saeli in reply to Alberta Mike, 12-14-2004 16:07:47
Hey Mike: I e-mailed you but it was returned. Anyway, these boots measure 2" high, 9/16" at the top & 1 3/4 at the bottom. I wonder if yours is stretched. These go on hard. They have to be lubed 1st. I use old veggie grease.
Alberta Mike
12-14-2004 19:46:47
 Re: Paging John Saeli in reply to John Saeli, 12-14-2004 17:32:03
The top might be OK (probably tight) but I think the bottom would be much too small I'd guess. This one fits nicely and snugly it's just that it is so weathered. I'll keep checking things out. My email provider for some reason rejects email from at least a couple of email service providers, they've never really given me what I think is a satisfactory reason. SCB Global is one and also some other outfit that I know of. Thanks for your time and have a nice Christmas.
Alberta Mike
12-14-2004 15:51:24
I will go out and pull the old one off (under a tarped chassis) later tonight and get the measurements of this original which is pretty cracked and weathered. My email address is [email protected] so if you emailed me I could get back to you with them (otherwise I can post them here on the forum).
