Case580 ck identification
Peter Booth
12-14-2004 00:47:35
Hi all.
My local parts dealer here in tassie is having trouble finding info to order the parts i need to repair the diesel motor in the old backhoe. can any-one help with a year model etc for it. The best i can tell which is on a plate on the side of the block (very worn). Looks like Maybe C or G then maybe a 1 then 88D
Next under that is 2692 maybe an 8 then 87. Cast into the block is CWCS109 and A38535.
cast into the conrod is G11723.
Cast into the piston is A38424.
I need a head gasket, Rocker cover gasket, Rod eye bearing, 1 Ring set for 1 piston, sump gasket, upper timing cover gasket(the one between the head and water pump). any help would be appreciated. They are looking under 188 diesel engine, but it then says 1st used eng. ser. no 2767997. which seems later than mine.
AGAIN ANY HELP PLEASE.
Peter
andy knaebel
12-14-2004 09:00:15
 Re: Case580 ck identification in reply to Peter Booth, 12-14-2004 00:47:35
I have a 71, 580CK backhoe / loader with 188Deisel. I have been using ESS in Atlanta, my local CASE dealer. They have been very helpful finding part numbers and getting the parts for me. 404-696-8005. My engine is SSN# 2704609 so I don't know if this will work or not, but I just bought a head gasket from them. It was case part number 1349116C1. I have not purchased any of the other parts on you list so can't help with those.
