What do you think
randall s grant
12-13-2004 14:55:11
I have a case 1410 that needs to be bored. Currently its .030 over. Aftermarket sells .040 over pistons and rings. Case only offers .020 over or sleeves that can take it back down to standard. My gut tells me to go with the sleeves but that is quite a bit more money by the time you buy the parts and the extra work for the machine shop. If anyone has had one of the browns bored to .040 over i'd like to hear the results
kyhayman
12-13-2004 16:27:11
 Re: What do you think in reply to randall s grant, 12-13-2004 14:55:11
I've done a bunch of the AD54 engines. The 1410 apparently uses a different hardening method on blocks and cranks which only allows .030 blocks and .020 on the crank. Also, be real sure that those .040 pistons are 1410 material and not made up for a 1210.
I'd sleeve it and take it back. Not all that much more money. Shop I use charged me an extra $200 plus the costof the sleeves. Took 1 day more.
