Case 300 hard start or hand crank
pajon
12-13-2004 09:17:20
Hi,
I have a 300 and unless my new 6 volt battery doesn"t start it on about the 6th turn over, it"s over and bat needs charging. This is re-occuring and is not the battery.
Could it be the starter? Anyone have an old crank?
HobbyFarmerInWI
12-13-2004 18:39:19
 Re: Case 300 hard start or hand crank in reply to pajon, 12-13-2004 09:17:20
My did the EXACT same thing. Moved to the #2 cable and all is well now.
pajon
12-17-2004 13:29:34
 Re: Case 300 hard start or hand crank in reply to HobbyFarmerInWI, 12-13-2004 18:39:19
Thanks to everyone. The #2 cable seems to help the most, plus I had a poor battery (Only 1 yr old)
Gene Dotson
12-13-2004 13:41:20
First of all, make sure the battery and starter cables are heavy enough to carry the load. Conductor should be about the size of your little finger. Next step is to crank the engine with the ignition off till it starts slowing down and then carefully feel all the connections for heating, particularly the starter button. This will indicate where resistance is high. Chances are you will find a connection or cable not capable of carrying the load... Gene
C. Amick
12-13-2004 14:27:28
 Re: Case 300 hard start or hand crank in reply to Gene Dotson, 12-13-2004 13:41:20
Should be at least a No. 2 size cable. Some people use the larger No. 1 cable.
Coloken
12-13-2004 13:22:00
Got to disagree. Any good 6 volt battery will hang in there longer that that. As a class, they hang on longer that 12 volt one. Unless you starter is shorted, and then some thing would be realy smoking. My 300 starts on 3rd flip, 2 quarter turns to choke and fires on third.
Coloken
12-13-2004 13:25:41
 Re: Case 300 hard start or hand crank in reply to Coloken, 12-13-2004 13:22:00
Second thought. Starter is draging. gets warm and drags. While you are recharging battery, starter is cooling off. Try waiting for it to cool off without recharging battery and see what happens.
pajon
12-16-2004 14:38:07
 Re: Case 300 hard start or hand crank in reply to Coloken, 12-13-2004 13:25:41
Hi Again,
I let it cool off and it seems to help a little. Should I replace the starter?
pajon
12-16-2004 16:31:51
 Re: Case 300 hard start or hand crank in reply to pajon, 12-16-2004 14:38:07
I wrote wrong. when I bi-passed the selonoid it would NOT turn the start motor very well
pajon
12-16-2004 14:40:36
Thanks for your advice.
I bipassed selonoid to the starter and it would respond very well. Was that stupid or does that indicate the starter problem.
John
