Case V pulley
Gord McFarlane
12-13-2004 06:30:34
I need a pulley including drive for a Case V. Does anyone know if a pulley assembly from a V A will work or must it be off a V Thanks Gord
Gene Dotson
12-13-2004 11:24:29
 Re: Case V pulley in reply to Gord McFarlane, 12-13-2004 06:30:34
Gord, where are you located? I have a complete pulley assembly from a VC that will fit your tractor. My e-mail is open... Gene
Alberta Mike
12-13-2004 11:22:36
I have a Case history book here that says that there are virtually NO interchangeable parts between a V and a VA, however I have found out that there are a number of items that are exactly the same. For one, the clutch shaft (between the clutch and the transmission) is identical as are all the seal holder housing, seal, bearings, splines, and also the bevelled drive gear which drives the side-mounted belt pulley assembly. All of that stuff is shaft mounted in exactly the same location. My clutch shaft with gear, etc. was toast and I have one from my friends parts tractor VA and I plan on using it next spring when I start reassembling things. The throwout bearing and it's mechanism are also identical. The VA tractor this came off had the hydraulic pump/belt pulley assembly on it (my V just has the pulley assembly). I would say that the VA belt pulley would match up perfectly with a good guess from what I have seen of these parts.
Gord
12-14-2004 08:25:45
 Re: Case V pulley in reply to Alberta Mike, 12-13-2004 11:22:36
Thanks for the replys and input. Gord
Jerry W
12-13-2004 06:43:49
I do not absolutely know for sure but I doubt that it will work. Few parts actually swap between the V's and the VA's.
Jerry
