Help identify old case
greg m
08-29-1999 16:08:10
trying to identify an old case tractor, maybe a case DC. 3 forward speeds, hi/lo shift, wide front nonadjustable, hydraulic pump below pto, 2pt hitch, 4 cylinder gas. What else might help? looked for a serial number but could not find one.
C. Amick
08-31-1999 09:35:37
 Re: help identify old case in reply to greg m, 08-29-1999 16:08:10
Is the grille cast iron or steel? DC's have cast iron grilles.
greg M
09-01-1999 05:38:12
 Re: Re: help identify old case in reply to C. Amick, 08-31-1999 09:35:37
grill is ,missing
greenfrog
08-31-1999 18:46:28
serial number is stamped on side of engine block right on edge were the two halves of the tractor engine and trans are bolted toghther the plate serial number must be gone huh?
greg m
09-01-1999 05:41:37
 Re: Re: Re: help identify old case in reply to greenfrog, 08-31-1999 18:46:28
did not see it, maybe painted over. I'll check again.
Few new things: has eagle hitch means it was built
after 1949, hand clutch, means built before 1953.
that hi/lo shift may not be. I took the guys word for it. in which case thai may be a DC3.
