case 1070 powershift
jwb
12-13-2004 04:19:55
i recently purchased a 1976 1070 and when you push inching clutch in it fills like reverse is trying to ingauge. also motor speeds up.power shift works in all gears and powershift ranges.any help appreciated
c hess
12-13-2004 17:00:57
 Re: case 1070 powershift in reply to jwb, 12-13-2004 04:19:55
your p shift is working correct. throttle back at instant it makes itslaboring sound you can shift gears an not grind gears especally when cold. after tractor warms up if you throttle back an do not push clutch completely in you should also be able to shift gears with out grinding .the sound you hear when pushing clutch all way in is trans going in reverse, this is normal but should be avoided at full throttle!!
