clutch and steering on case 580 CK?
johnnydindemingwa
12-12-2004 21:54:01
I am looking at a case 580Ck with a mechancal shuttle. in looking at the clutch through the inspection hole it looks to have a bit less than 1/8th inch of material on eahc side of the cluthc plate. THe clutch does not clip even when I put the brakes on and try to move it in the upper gears. the engine will bog down. with average use about how many engine hours would one expect this clutch to last doing mostly hoe work, and how thick is a new clutch? I have put clutches in cars and trucks, but this thing looks like a really big job to split and put a clutch in. Is it a reasonalbe job for a average mechanical person with a couple of good floor jacks and stands to do?
the other issue is the right side axel where it hooks to the arm at the top turns when teh steering wheel is turned. after a bit of slop the wheel then turns. I cna see that the movement is under the big nut on the arm hooking to the upright of the axle. ( I am calling the L shaped piece that the wheel mounts on the axle)
thanks for your advice. johnnydindemingwa
G.B.
12-18-2004 07:51:07
 Re: clutch and steering on case 580 CK? in reply to johnnydindemingwa, 12-12-2004 21:54:01
As far as the axle goes. Click on "ARCHIVES" near top of page. Then click on sorted by author. Then Pg. 96. Then third subject down about spindle. Then on Marcs reply. Then on "illustration". It"s a 530CK but I would think it"s the same.
Dennis/Ohio
12-16-2004 09:27:37
I have a 530 backhoe with dry clutch and mechanical shuttle. I think they are similiar. If the hoe is removed first. the back half can roll on the rear wheels and a floor jack.
To do it the other way you almost need an overhead crane to carry the weight of the loader. The loader frame is the headache. On a farm tractor you could easily go either way. I'm thinking....(this could be bad...ha ha.) Can you tie the clutch pedal down and feel how deep the rivets are from the clutch face with a piece of wire? I've never worked on your style front axle. Maybe that arm can have some material ground out of it and clamped tighter?
My two cents, Best wishes, Dennis..... ..
