cleaning the rear-end
Got the FEVER
12-11-2004 20:07:49
I drain the rear-end of my case "s" it was real dark & thick....the book I have says to FLUSH it out..but doesn't say w/ what...Any advice would be "greatly " appriciate....I'm new at this ...but love these old tractors...THANKS for any help you can give me...Mark
Dick L
12-12-2004 05:39:54
 Re: cleaning the rear-end in reply to Got the FEVER, 12-11-2004 20:07:49
On real dirty transmissions with a thick coating of crud, I take all the covers off and use the high pressure washer on them using a strong detergent thru the washer. Blow out with compressed air and let dry for a while and then spray with WD 40. That will expell the remaining water. Then it is ready for new fluids when you are.
Don Rudolph
12-11-2004 20:39:42
We use about 10 gals of diesel fuel. We just run it around in there for a few minutes and drain it and refill with the correct fluid.
