HI POWERED SC FOR PULLING ?
CTS
12-09-2004 07:47:42
Aneyone ever bored and stroked a SC CASE i hear a lot of stories on wc wd allis and farmall h but none on sc, my sc balances better in stock form then either of them, and the price of stock parts on sc i could modify with out mutch extra cost, i wonder about the kind of HP could be maid if the same kind of $ were put in it as a H, they start out as large as a super H. any input would be great, thanks cts
Don Livingston
12-11-2004 10:55:15
 Re: HI POWERED SC FOR PULLING ? in reply to CTS, 12-09-2004 07:47:42
The late block has extra wide sleeves, can be bored to a much larger bore. I remember one guy put 4 inch Cadilac pistons in the wide sleeve. That block came out around 1952 or 1953.
Don L.
Goldie
12-13-2004 20:54:50
 Re: HI POWERED SC FOR PULLING ? in reply to Don Livingston, 12-11-2004 10:55:15
Do you know if that block will fit in an older SC.
CTS
12-11-2004 20:28:30
thanks don and others for your info. cts
CTS
12-09-2004 19:16:30
My SC is rebuilt with 3 5/8 pistons and makes around 34 HP it weighs 4500 with me on it and pulls usualy in the top 5 with only weight brackets and a pulling plate on the stock drawbar, the problem is 5000lbs and 5500lbs classes is with dc,m,a, and others and its out classed.
Goldie
12-09-2004 18:43:56
I'm working on a 43 sc right now. It should make a good puller it only wieghs 3400 lbs. I'm trying to get the motor aroud 200ci.
todd hamilton
12-09-2004 17:27:04
Dad always said the trick to make an SC pull was to have worn rear tires so it will spin enough in 2nd to rev up the engine. After he put new tires on it, it didn't do as well. He ran stock bore and pistons with an LP head on a 41 SC. That high compression head makes all the difference. My stock 44 doesn't have near the snot his did - but I need rings, valves, carb, etc. That old 41 would raise the front end in 1st "real easy."
dctom
12-09-2004 08:50:39
ALWAYS WANTED TO TRY TO GET THE SAME AS A DC IN AN SC, THINK IT COULD BE DONE BUT I AM TOO OLD NOW TO EVEN THINK ABOUT IT, JUST THINK 260 CI AND MORE RPM'S WOULD MAKE THOES H'S AND WC'S LOOK SMALL DCTOM
C. Amick
12-09-2004 08:08:19
I think the AC WD has 4-inch or larger pistons and has around 200 cu. inches of displacement stock. The SC is probably heavier and has only around 167 cu. inches with the 3-5/8" pistons. From what I hear, the Case VAC, DC and LA are the more competitive tractors of that era.
John H-WI
12-09-2004 14:10:57
 Re: HI POWERED SC FOR PULLING ? in reply to C. Amick, 12-09-2004 08:08:19
We had many SC's back home on the farm when I was there and always thought they were better than the H or B but the Super H had more horses. Always found that the SC was too heavy for the horses it turned out. Never seen anyone successfully make the SC a good puller not that it couldn't be done although the V, D, and L make better tractors to modify for pulling.
