VAI - Do parts fit a VA?
Robert Shirley
12-09-2004 05:43:57
We have the opportunity to purchase a Case VAI and wanted to know if we can use parts from a VA to fix it up. We have tried parts from a VAC and they don't work. Anyone know? Also, anyone have any original or copies of manuals for this thing? Thanks!
jean claude marleau
12-09-2004 21:04:13
 Re: VAI - Do parts fit a VA? in reply to Robert Shirley, 12-09-2004 05:43:57
I do have a parts manual for VAI my e mail is [email protected]
Gene Dotson
12-09-2004 16:17:14
Virtually all parts from the VA and VAI will interchange. The major difference is the front axle. The VAI axle beam is heavier and uses a double mount in the center pivot. The front inner wheel bearings are larger. VAC wheel, axle and front end parts will not interchange. Steering gear is different from VAC with different length arms. Transmission ratios in most VAI's are higher than VA and VAC's. Sheet metal will interchange, keeping in mind the later model changes... Gene
Robert Shirley
12-09-2004 16:19:27
 Re: VAI - Do parts fit a VA? in reply to Gene Dotson, 12-09-2004 16:17:14
Thanks so much for the info
mikefromiowa
12-09-2004 07:26:49
It would depend on what parts. I would assume most would interchange, but I would think a VAC would also.
