stop rust
Ky Ted
12-09-2004 04:01:44
I am taking the old paint off an old tractor, it is going to take me several weeks and i need to know how to stop it from rusting where i have already cleaned, if there is something to use where can i get it. thank for the help i need all i can get.
Keith-OR
12-09-2004 18:41:08
 Re: stop rust in reply to Ky Ted, 12-09-2004 04:01:44
F-I-T (Frank's), Information really works!! I used OSPHO,Brand name of Ace Hardware, On a Allis Model C that I was doing last spring, Need the room in the shop so had to push tractor outside. Figured it would only be week or so.But ended up being over a month, during an unusal rainy season, NO rust just turned bare metel a milky color. When time permited, got tractor back into the shop and primered then finally painted.
Tracy brown
12-09-2004 11:14:07
The best product I have used to strip paint is aircraft stripper found at a local body shop supply. Follow the directions and keep it off of you. It's strong stuff.
680e trouble
12-11-2004 06:17:56
 Re: stop rust in reply to Tracy brown, 12-09-2004 11:14:07
working in the airline industry there are a lot of special chemicals we use however one product we use is just " LPS 3 rust inhibitor " you can buy it off the shelf ,I use it at home for spraying down engine blocks after they are cleaned and stuck outside ,it goes on tacky but then dries to the touch it comes off with gasiline ,degreaser ,etc
chvet73
12-09-2004 09:46:24
Rust never sleeps. Protect as you go. It may not look like it but metal is rusting as long as it's not protected.
F-I-T
12-09-2004 09:22:35
Although I prefer to apply epoxy primer as soon as possible after cleaning, several applications of phosphoric acid, allowed to crust up quite a bit will give you pretty good protection from re-rust. I store a lot of parts in humid Florida that way while they wait on paint.
Frank
C. Amick
12-09-2004 05:38:36
If you can get it down to the bare metal, put primer on it. If there is some rust that you don't get off buy some "kill rust" stuff to put on it. It reacts with the rust to form a protective coating. It's available at NAPA and automotive part stores.
John Saeli
12-09-2004 05:10:03
Hey Ted: Prime it as you go. What are you using for paint remover? I can't find a good one.
Gene Dotson
12-09-2004 16:06:07
 Re: stop rust in reply to John Saeli, 12-09-2004 05:10:03
John; The best paint remover I have found is "Dad's Easy Spray" It is available at Lowe's, Home Depot and Meijers. Comes in gallons and quarts. I have found that to prevent rust here in humid Ohio, that if I put up a fan and keep the air circulating that the parts won't rust. Have sandblasted parts and put them in the back of the shop with air blowing over them for 2 weeks and no rerust... Gene
John Saeli
12-10-2004 04:49:29
 Re: stop rust in reply to Gene Dotson, 12-09-2004 16:06:07
Hey Gene: Thanks for the tip. I got some Aviation Stripper yesterday. I'll let you know how well it works when I try it.
