CASE diesel 580 CK info please
johnindemingwa
12-08-2004 21:33:39
Hello, I am looking at a diesel 580 CK serial number 2270174. it has a loader and backhoe. The unit is in good or better shape with worn tires cylinders are in nice condition, some seals leak everything works. I can see no weld cracks and only one place on the loader that a doubling plate has been welded on. It comes with 24" and 12" buckets. no ROP.Total hours are unknown. It is a 4 speed with a mechanical shuttle (you have to push in the clutch to shift it) This unit looks like a 580 B to me with less stuff on it? I would appreciate suggestions as to things to look for on it, value suggestions, specs and and year. I have read the 14 pages of posts and not found this info. thanks for your help. Sounds like a good group for information. john
agri_con
12-09-2004 02:41:33
 Re: CASE diesel 580 CK info please in reply to johnindemingwa, 12-08-2004 21:33:39
B-hoe swing tower pins and bushings,upper and lower
main boom pin at swing tower these are all checked by putting a little down pressure on boom and checking to see how much play is there
look @ the b-hoe mounts to tractor
front axle king pins,axle mounts ,plus a frame mount to oil pan
loader cutting edge
normal eng stuff a/f/ water pump bearing,oil,excessive smoke etc.
Don't fret anything vintage,you'll probally have to stick a few $ into it
good luck
