Plugs are fouling differently, what's up?
Robert Paris
12-08-2004 08:54:33
My old VAC is acting up again, I guess the Old One does not appreciate sitting in the cold. While checking the spark plugs I noticed that plugs 1 - 4 seem in better shape that than plugs 2 -3 who are fouled with oily sooth. I'm not much of a mechanic but I'm sure that this means something. Any hints ?
Happy holidays to all !
Paul f
12-09-2004 08:06:26
 Re: Plugs are fouling differently, what's up? in reply to Robert Paris, 12-08-2004 08:54:33
Bob: As the other postrs indicate it may be time for an overhaul. Have you tested the compression..will bet 2-3 are much lower than 1-4. (If you do the test make sure engine was warmed up). If 2-3 are lower try putting some gear oil in each spark plug hole then test again...if readings improve it is most like worn/broken rings...
The hotter plugs will help for awhile and if you aren't working her hard she will probably run along time.
C. Amick
12-09-2004 05:44:29
If the plugs are oily, your getting oil leaking past your piston rings. In addition to the hotter spark plug, you might want to put a bottle of oil treatment in it the next time you change your oil.
Gene Dotson
12-08-2004 16:18:06
Plugs fouling with oily gummy deposits usually indicate worn piston rings. Probably time for overhaul. You probably should use a hotter plug, like Auto-Lite 387 or Champion D21. Standard plug is D16 and for light use, will tend to foul, particularly in cooler weather... Gene
