Case-o-matic is dead
John Sam
12-08-2004 08:00:55
I have a Case w-3 (circa 1958, I guess basically just an industrial version of a 530) that sat for about 25 years. I just rebuilt the engine and got it running again but now it won"t move. I haven"t checked the pressures yet but cracked the filter in front of the radiator and got a geyser of oil. When I pulled the engine the converter & what else I could see looked nice & clean, old oil wasn"t burnt & looked clean, no water in it. Drained everything including the converter and replaced oil with new 10wt. Don"t hear any bad noises inside and only a slight buzz (with the stethescope) around the valve body & pressure regulator. Stepping on the clutch does nothing. Any case-o-matic experts out there with any suggestions? Information on these (service manuals, etc) seems hard to come by. I only have an old IT manual. Any advice would be appreciated. Thanks!
John Saeli
12-09-2004 05:14:52
 Re: Case-o-matic is dead in reply to John Sam, 12-08-2004 08:00:55
Hey John: 1st thing you have to do is check them pressures. The good thing is that you have flow. Was the converter OK when it was parked 25 yrs. ago? It's possible the teeth are wore off the fibre clutch plate in there. Stupid question, but you're sure the range lever is engaged as well as the shuttle?
