49 case sc lifting bail hole size needed
kirk wannemache
12-08-2004 06:32:42
Can anyone tell me the size of the hole on the lifting bail of a case sc 1949. The diameter would help so I can buy pins today, I am at work and want to stop today and forgot to measure. Any help would be appreciated
C. Amick
12-09-2004 07:48:24
 Re: 49 case sc lifting bail hole size needed in reply to kirk wannemacher, 12-08-2004 06:32:42
I realize it's too late now, but I fastened 7/8" Cat. 1 Lift Arm Draw Pins in the holes in mine when I made it into a 3-point hitch. I welded an additional pin at the base of the lifting bail on each side. I used these pins to hold the flat steel lifting arms to the outside of the lifting bail. I also added a 2nd. hydraulic cylinder to the right side.
