500D Voltage Regulator Options
john in quick,
12-06-2004 15:19:53
Hi All!
Awhile back I posted about battery woes and overcharging. The batts are 6Volts (2 of em) - 2 yrs old. They were fully charged and then I went for a 10 minute snow plow and smelled sulphur at the end - turns out they were both boiling! Ammeter says charging at 15 Amps right now. Consensus from the Board was voltage regulator faulty.
Took cover off of regulator this weekend, but all I see is 2 coils and 3 wires. 2 coming in one going out. How can I fix this myself? What should I look for...or can I fix this (with basic multitester)? There is a set of points on each coil too. Cheap fix is to put a switch on the charge wire, or just disconnect, then I can use batts for starting/running lights, and then put back on trickle charger when done. Any other ideas? Love to keep my Case top shape and original, but dont want to get dinged for $$$ and new regulator- just guessing here. Is there an equivalent jobber part #? Appreciate the advice.
john in bc canada, -14C and sunny today.
Vernon Teall
02-19-2005 05:18:22
 Paint Colors for a 1952 Case VAC in reply to john in quick, BC, 12-06-2004 15:19:53
I need infor on the correct color and brand of paint for a Case VAC, 1952 yr. This is being restored for a farm and forestry museum and need to be correct. I also need a source for Decals.
Thanks Vernon Teall
Vernon Teall
02-19-2005 05:17:37
I need infor on the correct color and brand of paint for a Cace VAC, 1952 yr. This is being restored for a farm and forestry museum and need to be correct. I also need a source for Decals.
Thanks Vernon Teall
Duner Wi
12-07-2004 16:55:32
 Re: 500D Voltage Regulator Options in reply to john in quick, BC, 12-06-2004 15:19:53
I assume you need a regulator, if you have 12 volt generator # GHH 6001E-1,J you may be in luck with Neihoff reg.#AL 152T. If you have a different # generator post it and I will see what I can do.
john in quick, BC
12-08-2004 21:02:54
 Re: 500D Voltage Regulator Options in reply to Duner Wi, 12-07-2004 16:55:32
Hi Duner
Thanks a bunch for that part # on the regulator - I wil check to see if I have that generator tomorrow when its light out, and if so then track down that # you gave me, if not I'll post a reply..
thanks agian,
john
