Case 480D hoe lever arms
Randy Shelley
12-06-2004 09:34:50
Does anybody have any used lever arms for the hoe on a Case 480D? I bought a 480D about a month ago and when I was pulling up a stump one of the arms connecting the hydraulics piston to the bucket cracked. When it broke it bent the other arm beside it and bent one of the other arms connecting the hydraulic piston to the outer boom. I think I can heat up and bend that arm but I would like to replace the two outer arms connecting the piston to the bucket. Any suggestions would be greatly appreciated.
Dennis/Ohio
12-16-2004 15:26:07
 Re: Case 480D hoe lever arms in reply to Randy Shelley, 12-06-2004 09:34:50
Hi, Did you also post on the Crawler, Dozer & Backhoe forum here on YT site?
If I understand what you"re working on. Its all mild steel parts and you can bend and weld as needed.
