SC voltage reguator
CLIFF
12-04-2004 17:36:51
where can i find one? its a autolite 6V with a fuse bult in. case says its no longer available. the tractor is a 49 modle if this helps. thanks cliff
C. Amick
12-09-2004 09:01:56
 Re: SC voltage reguator in reply to CLIFF, 12-04-2004 17:36:51
Cliff, if you can't find the right regulator let me know and I can get the number off mine for you the next time I am up at the farm.
jstpa
12-05-2004 20:13:40
Cliff, It is a regulator, and an oddball one at that. You should be able to get it, or order it, at any generator rebuilders you have in town. They are expensive though. If you can't find one, email me and and I'll order you one. JSTPA
CLIFF
12-06-2004 05:47:51
 Re: SC voltage reguator in reply to jstpa, 12-05-2004 20:13:40
Thanks jstpa i will check our in our aera, I would like to keep it oem, Its a real nice tractor that just needs new paint to make it perficit,I need to get it reddy for our CASE SHOW labor day weekend in central Pa. If i cant find a regulater localy i will email you, thanks CLIFF
AUSTEX
12-07-2004 07:41:56
 Re: SC voltage reguator in reply to CLIFF, 12-06-2004 05:47:51
I would also like to find a source for an oem style regulator for my 53SC. The local generator shop installed a cutout relay on my gen and it seems to be overchargeing. Apperantly 6V saddle mount neg. ground regulators are not easy to come by. I'm considering switching to pos. ground as those seam to be more available.
Geoff
Scott KY
12-05-2004 09:37:16
More than likely it's a cut out relay instead of a regulator. Some of the generator rebuilders offer a cut out replacement but it won't look original. It is possible to hide the new relay somewhere and run the wires to it and leave the non working one on the generator to look original.
CLIFF
12-05-2004 19:16:28
 Re: SC voltage reguator in reply to Scott KY, 12-05-2004 09:37:16
are you sure it knot a reguator it has 3 wire hook up and works just like my farmalls.
C. Amick
12-06-2004 07:44:47
 Re: SC voltage reguator in reply to CLIFF, 12-05-2004 19:16:28
It came from the factory with a cut out relay and a negative ground system. There was a resistor mounted under the dash to help prevent over charging. I got rid of the relay and put voltage regulators on my SC's keeping the same generator. Sounds like someone has done the same thing to your tractor. Voltage regulators are available for your generator, some regulators are labeled as to whether they are for neg. ground systems or pos. ground systems.
