Case 530/540 gas carb
Dennis/Ohio
12-04-2004 16:41:05
The carb tends to flood when setting. Its a zenith #12509 Case# G45772. I"m thinking a needle and seat will fix the problem? Any helpful hints? I"ve noticed many are not happy with the Zenith and prefer Marvel-schebler# TSX-799 Case# G45773. It wouldn"t be cheap to switch carbs and how well would it fit?
thanks, dennis..... .....
JRT
12-06-2004 21:12:03
 Re: Case 530/540 gas carb in reply to Dennis/Ohio, 12-04-2004 16:41:05
Dennis, I think people are right with their preference of the Marvel Schebler. I have a 530 with a zenith and other old cases with the marvels and they run better in cold and are easier to adjust . My zeneth kept leaking after I had it rebuilt and the fellow who rebuilt it kept telling me I had a piece of grit under the needle. I finally tore it down myself and found the pin holding the float in was too short, which allowed it to slide out and get the float off its hinge. I made a new pin from a finish nail and that is all it took to fix it. The mechanic told me he used the pin that came with the rebuild kit. You might check and see if yours may be the same.
