VAC pulling
Kevin
12-04-2004 15:41:23
Is it possible to make a VAC a pulling tractor? Probly do the 3500lb class so far from what isee the weight is. I deffinatly need some info on this tractor though, i never saw one pull but i would like to try it.
49vaccase
12-09-2004 06:55:03
 Re: VAC pulling in reply to Kevin, 12-04-2004 15:41:23
My brother and I both pull our VAC's in the 2500lb class. You will get creamed in the 3500lb class unless you bolt an early 148CID engine in. Then it is possible to put enough of the 159 parts in it to make it somewhat competitive. Unless you do what casepower did, BUT you had better me a machinist and be allowed to bolt in a combine motor! I love my little VAC,but you can do so much more with an AC WC (and very cheaply), that you will never be able to beat them with power. Go to www.oldpowerpride.com to see the EXTREME of what you COULD do IF the rules allowed. The ABOUT 1953 Vac's and newer weighed alot more than the late 40's due to the eagle hitch. To get one lighter than 2500lb, take off the PTO, belt pully, and all cultivator stuff. If you want to get lighter, bolt on massey harris 44 (I think) rear center hubs with the 9 bilt holes and mount pressed steel rims like I did. Your wheel size options are endless after that (if you can turn them).
DCPULLER
12-05-2004 14:41:07
Kevin, I can point you in the direction of one ready to pull if interested. DCPULLER
dctom
12-04-2004 15:55:43
YOU BET YOU CAN, THEY WILL LAUGH AT IT UNTILL AFTER YOU PULL
CLIFF
12-04-2004 17:54:51
 Re: VAC pulling in reply to dctom, 12-04-2004 15:55:43
theres some that pull real well here in PA, most have new engine kits and 13.6-28 back cut tires and start in our 2500lbs class(2600 with driver)threw 3500lbs. i have one with non cut 9.5-32 thati plan on pulling next year in the non cut tire class but i think my allis c will easily out pull it with those little tires. wee will probley need to change to 28 inch tires. cliff
Kevin
12-05-2004 17:43:03
 Re: VAC pulling in reply to CLIFF, 12-04-2004 17:54:51
Are these tractors really stripped down to pull in the 2,500lb class? I saw some were that the VAC weighs 3,400lbs.
Kevin
12-04-2004 19:12:01
What is the stock rim size? I dont have alot to spend. I dont even know if i will get the tractor yet, the guy that has it hasnt emailed me back yet, its the one in the photo adds for $1,100 obo in syracuse NY. Maybe im lucky anough to be talking to you right now. Anyways, i want to keep it mostly stock except for maybe the width of the tire.
FarmallCaseGuy
12-05-2004 06:31:11
 Re: VAC pulling in reply to Kevin, 12-04-2004 19:12:01
I beleive the Stock size was either a 9x28 or 10x28 (older VAC's anyway), so in new tire sizes that would be 9.5x28 and 11.2x28.
Kevin
12-05-2004 17:41:41
 Re: VAC pulling in reply to FarmallCaseGuy, 12-05-2004 06:31:11
So its a 28 rear tire? Is it posible to do a 12.4x28 or a 13.6x28 on it? DCPULLER, i would love to take you up on the offer but as i said i dont have tons of cash to spend and i need a local deal.
CLIFF
12-05-2004 19:26:55
 Re: VAC pulling in reply to Kevin, 12-05-2004 17:41:41
these VAC,s are striped if you started pulling them around 3500 my wifes super c would give them a lot of greaf. there tuff to beat in 2500 lps and very strong in 3000lps class. 32 and 34 inch tires were options. cliff
