Case 441
Bernard le m�ca
12-04-2004 15:16:12
Hi, a friend of mine have a Case 441. I'm not a guru for those old Case and i search a 441 pro. He want to put a snow-blower on his tractor but the PTO stop when he push the clutch pedal.The hitch raise the snow-blower but don't stay up. May be the draft or raise lever are not in position or a leak in the hitch system. Is the 441 have a dual clutchs? Thanks Bernard le m�cano
case poor in pa
12-07-2004 16:57:47
 Re: Case 441 in reply to Bernard le m�cano, 12-04-2004 15:16:12
there should be a hand clutch to use .is there a lever on the side of the transmission that sticks up toward the dash somewhat? using that will let the pto run. takes a few times to get used to it.
