LA Thermostat
Ralph NH
12-04-2004 14:54:13
Does anyone out there know why my 1949 LA doesn't have a recessed lip in the upper end of the radiator elbow to accept a thermostat? When I took it apart, there was no thermostat and no lip. My '41 has one and my '51 has one. Any help is a help.
Larry Martin
12-05-2004 16:56:53
 Re: LA Thermostat in reply to Ralph NH, 12-04-2004 14:54:13
I put a thermostat in my DC by cutting the gasket out for the thermostat and mounting it between the flanges in the connection. Works fine.
Steve-MN
12-05-2004 09:55:12
My 49 LA does have the lip in the elbow(& a thermostat). I don't think I ever had shutters on mine but I'm not sure of that. Now that's just one more thing I wish I would have asked Dad about:). I'd put them back on if it had it originally.
Interesting.
Steve
Brian in Ohio
12-05-2004 06:49:37
They didn't use a thermostat. Combinekid was right. THe temp was controlled by the shutters over the radiator core.
Ralph NH
12-05-2004 11:21:41
 Re: LA Thermostat in reply to Brian in Ohio, 12-05-2004 06:49:37
Thank you Brian in Ohio. Just the answer I was looking for. I guess the reason my '41 and my '51 LA's have a thermostat is because they are LAE units and not tractor units, even though they are exactly the same engine. My '49 has shutters but my power units don't. Interesting. Also, I want to put in a word of encouragement to combine kid....Keep on pluggin'. Thanks for your help.
combinekid
12-05-2004 00:14:26
I dont know if this is correct or not because I just got an LA and don't know much about them. My service manual says that You use the radiator shutters to control heat so maybe you dont need a thermastat. This is just a thought. I have a 48 I am disesimbling now but I have not removed that elbow so I guess I dont know if it does or doesent have a thermastat.
