case dc 1955
dc man in pa
12-04-2004 09:06:22
what kind of oil do you use in the clutch housing
Glenn FitzGerald
12-05-2004 07:31:42
 Re: case dc 1955 in reply to dc man in pa, 12-04-2004 09:06:22
I've been waiting for this question to surface...Did you say your DC is a '55 model? I understand some dealers had new DC's on their lots as late as '57 due to the 400 taking over in '55, but I don't think any DC's were '55's according to their serial number...Were they? Glenn F.
Scott KY
12-04-2004 10:12:46
The oil from the engine will flow into the clutch housing. You drain the oil out separately but it will fill from the crankcase.
dc man in pa
12-04-2004 13:02:44
 Re: case dc 1955 in reply to Scott KY, 12-04-2004 10:12:46
thank you i drained this clutch housing and found a lot of water and want to replace it now i guess an engine oil change is next too what kind of oil goes into the final drives once again thank you
Paul f
12-04-2004 15:52:07
 Re: case dc 1955 in reply to dc man in pa, 12-04-2004 13:02:44
90 weight for trans and rear end.
Your hydraulic pump is a separate reservoir. Originally Case specified 10w...if the PTO clutches were replaced after mid 50s changed spec to DEXRON
dc man in pa
12-04-2004 16:19:41
 Re: case dc 1955 in reply to Paul f, 12-04-2004 15:52:07
once again thank you both for helping me im new at these computers but i find this a great web site are there others like yt?
