David Brown tractor pulling
Kase
12-04-2004 04:13:30
I was wondering if anyone out there in the world pulls a David Brown at tractor pulls. I was thinking of building one just to be diffrent. Are there any web sites for David Brown pulling that anyone has seen? thanks
wilson
12-07-2004 14:22:08
 Re: David Brown tractor pulling in reply to Kase, 12-04-2004 04:13:30
Elmer were you able to get a rough estimate on freight for the housing???? I am thinking of going the other way and parting put the 380--885 Fixing to get the motor further checked out. The tech school could break it down to pallet sized units. Bill
Elmer
12-04-2004 04:50:39
Link There are 74 pictures here. One guy even has a bale of straw hanging on the front of his tractor. I am going to try to pull with a Brown too. Have all the pieces here to build one. Just need the time!
Kase
12-04-2004 18:00:56
 Re: David Brown tractor pulling in reply to Elmer, 12-04-2004 04:50:39
What are you thinking of building? I have lots of ideas and lots of parts. I just dont know how much my idea will take before it blows. I would love to talk ideas. thanks
Elmer
12-04-2004 18:22:25
 Re: David Brown tractor pulling in reply to Kase, 12-04-2004 18:00:56
990 chassis, 1200 final drives with 34 inch rims, 1200 engine, 1390 injection pump, 1200 front axle, L shaped front nose weights, possibly go to standard steering, but power steering would be much nicer! 990 12 speed transmission, and maybe turbo from 1394. I have no idea how far you could push it. I did have a 1494 do 125 hp. But i did not leave it there. Turned it back to 75hp.
Kase
12-04-2004 19:29:16
 Re: David Brown tractor pulling in reply to Elmer, 12-04-2004 18:22:25
I was going to put a 1494 engine in a old 990. Strip every thing i can off of it so i could pull it around 4500. I have a inline bosch pump setup from a late 1210. I thought a pump shop could get me more fuel than i could burn. I just dont know how much the little 219 could take. Was the one you got 125 out of was with the cav turned up all the way. Well do you think this would work? thanks
Elmer
12-05-2004 06:15:25
 Re: David Brown tractor pulling in reply to Kase, 12-04-2004 19:29:16
Yeah it would work. The 1494 i turned up had originally put up only 65hp from the factory. Got permission from Case to turn up the fuel. I had only turned it up just a little on the ring figuring it might not be enough, but when i dyno'd it i had 125hp. It could go higher, not sure if the driveline could take it. I guess if you go ahead and do it, you'll be the test victim if something goes bad! Did you see all the DB's on the pulling site. Looks like they are doing it over in Europe!
Elmer
12-04-2004 04:52:35
This site is in Dutch, scroll down and on the left click on Merkin, under Fotos.
