case 580 Super D Backhoe Shuttle Problem HELP
James Johnson
12-01-2004 09:46:21
When cold I put the shuttle in forward and works fine but starts acting up when the tractor warms up. Reverse always works fine. When warm if I put the shuttle in forward I have to give a little too much throttle to make it engauge. If after I have pushed something and let off the throttle it will disengauge then I have to give it throttle to engauge forward again. When in forward I have lots of power and will spin the back tire up aginst a pile of dirt. Any help would be great.
agri_con
12-02-2004 01:53:18
 Re: case 580 Super D Backhoe Shuttle Problem HELP in reply to James Johnson, 12-01-2004 09:46:21
Drain the shuttle oil and remove the pan,check for metal filings on the suction screen(pulls off)if the oil has a never seez look to it chances are the forward clutch return spring is broke (common prob)this in turn allows the forward clutch to slip.
