SC valves
Scott KY
12-01-2004 04:13:50
I have a customer in need of a complete set of intake and exhaust valves for an SC. Does anyone have a source?
Dug G.
12-01-2004 19:59:17
 Re: SC valves in reply to Scott KY, 12-01-2004 04:13:50
I purchased a new set of intake/exhaust valves, springs, and I think seats or guides from NAPA. This was only 4 years ago, and very reasonable. I just gave them the old case numbers and they croos referenced them. I"ll see if I can scare up the old receipt with the part numbers on it.
Dug G.
Bob DeVol
12-01-2004 19:37:53
This worked for me-- use Ford V8-289cid for the intakes. Ford 8N for exhaust. Guides wil have to be reamed over size (this also cures those worn guides) You might need new seats depending on head wear. Valve stems are about .060 shorter-should be plenty of adjustment-if not grind .030 to .040 off the rocker shaft stands.
CK Richard
12-01-2004 15:49:46
Scott I got mine at Marrhall's tractor parts Cynthiana Ky. It has been a year or two $ 113 dollers
Crispin
12-01-2004 06:57:44
I replaced all the valves in my '52 SC just 1.5 years ago. A local machine shop got them no problem but I don't know where. Motive Power and Paint in Glens Falls, NY 518.792.0921
C. Amick
12-01-2004 05:34:46
I got mine from Don L. in Minn. ([email protected]) or 507-433-0073 mornings. I think that they are also still available from Case/IH.
Scott KY
12-01-2004 19:04:03
 Re: SC valves in reply to C. Amick, 12-01-2004 05:34:46
I work at a Case IH dealership and we can no longer get them from Case. I will give this customer the information you all have given me. Thanks!
C. Amick
12-02-2004 06:49:12
 Re: SC valves in reply to Scott KY, 12-01-2004 19:04:03
As a last resort, there are automotive valves that can have the stems modified on them by a machine shop to work.
