Case 740 Comfort King
John Becvar
11-30-2004 11:08:25
I now own this tractor and need an owners manual. All I know is it is a Model 740 Serial # 8285645. I don't even know the year it was made. What manual should I order or can I get a photocopy from someone. I desparately need help! Thank you.
John Becvar
12-02-2004 08:54:07
 Attn: Gene Doton Re: Case 740 Comfort King in reply to John Becvar, 11-30-2004 11:08:25
Thank you for telling me that my tractor was made in 1966. How did you know..... .....from the serial # 8285645?
I'm looking for an OWNERS MANUAL, you know, the one that comes with the tractor when you but it. DO you know where I can copy/buy one?
I don't even know what kind of hydrolic fluid to use. Do you?
Gene Dotson
12-02-2004 13:20:35
 Re: Attn: Gene Doton Re: Case 740 Comfort King in reply to John Becvar, 12-02-2004 08:54:07
john; I have a small book put out by King"s books of radnor, Ohio that lists serial numbrs of a lot of the older tractors. Has a good listing for the case tractors. Book covers from 1940 to 1975. The address is P.O. box 86, Radnor, Ohio 43066. The manual for my 700 calls for type A (dexron) automatic transmission fluid. I have used universal hydraulic oil in mine for years and have had good luck with it. The reason they recommend transmission fluid is because of the PTO clutch which runs in the same oil. CaseIH tch fluid would probably be ideal for hydraulic, but is much more expenive... Gene
Gene Doton
11-30-2004 16:35:35
John; The tractor is a 1966 model. A sweet tractor to operate... gene
CK Richard
11-30-2004 14:55:58
try ebay they are on there alot good luck
petetx
11-30-2004 12:37:44
go to itshopmanuals.com I have found that these I&T manuals are very helpful
