Original Case Oil Pressure Gauge on eBay
Jeff4f
11-30-2004 10:53:35
This one only goes up to 30 pounds? I thought all gauges measured up to 60 pounds. When did they change?
Jeff4F
11-30-2004 14:06:04
 Re: Original Case Oil Pressure Gauge on eBay in reply to Jeff4f, 11-30-2004 10:53:35
What an education! Everyday I learn that I know less. Thanks guys. Might just be worth bidding on. Only starting at $2.99 - Jeff
Jeff4F
11-30-2004 14:03:30
What an education! Everyday I learn that I know less. Thanks guys. Jeff
Joe (Wa)
11-30-2004 13:11:14
This is an echo:
The factory oil pressure for the VA 124 cid engine is 12-20 psi with engine running full load 1425 rpm and at operating temp.
This oil gauge has an uncompensated bourdon tube movement that is non-linear. A new gauge will be factory calibrated at 15 psi and can typically have a 2-5% error at both ends of the scale.
Joe
Paul f
11-30-2004 11:19:25
It is for VACs. If you try to order an oil pressure guage from case under teh original #VT2249 it crosses to new numbers and you get an 80 lb gauge...VAC barely makes it register. Also most guages are most accurate in teh middle of thier range..thus running a VAC with a 60-80 lb guage may lead to inacurate readings. I got lucky and found a working one in the salvage yard
C. Amick
11-30-2004 11:11:54
VAC's only carry around 15-20 psi of oil pressure. I don't think the VAC gauges went above 30 psi.
Jim Yadon
11-30-2004 13:05:18
 Re: Original Case Oil Pressure Gauge on eBay in reply to C. Amick, 11-30-2004 11:11:54
VAC, VAH, VAS, are mechanical oil pumps with these pumps they are low pressure pumps. The manuel that I have says that if you have 13 to 17 lbs is standard for a used tractor. When the oil pressure goes below 10lbs. you need to either replace the oil pump internal gears with a kit(which are not availible anymore) our buy a new pump, or mains for around $110. Big issue is that you can replace the pump. Here is the biggy they cost from $650 to $750 per pump.
