VAC Worm Wheel
James Boyd
11-29-2004 21:17:03
Need to locate one. Mine broke 5 teeth before freezing in a hard left. Missed the fence by inches. Any ideas?? For a 1952 trike. Teeth on half the gear.
mikefromiowa
11-30-2004 11:23:49
 Re: VAC Worm Wheel in reply to James Boyd, 11-29-2004 21:17:03
Can you turn the gear around. My service manual says to turn the gear 180 degrees to reduce play due to wore gear. Don"t know if that works or not.
James B
11-30-2004 12:59:46
 Re: VAC Worm Wheel in reply to mikefromiowa, 11-30-2004 11:23:49
Problem is that this is a trike. The VT4208 part# is a full gear with 20 teeth. I need a gear that has 20 teeth just on one side, with the teeth cut out on the other for the steering stop. I cannot flip my current gear over due to no teeth on the opposite side. Any other ideas??
Paul f
11-30-2004 06:07:41
Jim: In July my Case dealer got me both the worm VT3735 $45 and the gear VT4208 $79 from Depot parts NOS
If you want used check with Don Livingston 507-433-0073 mornings best
Paul f
11-30-2004 06:07:38
