Case 811-b trans problems
Ryan Leasure
11-29-2004 16:31:26
I bought a 811-b gas wide front. The high range gear is ground off, so i don't have any high range. I am wanting to know if i can get a new gear if so how much and where at? And how hard is it to split the tractor and remove the torque converter and replace the gear?
Also how much is this tractor worth it is a 1958 811-B wide front gas, has matched pair of 15.5-38 rear tires and 7.50 -16 fronts. The tractor needs paint.
Thanks Ryan Leasure
John Saeli
11-29-2004 17:35:59
 Re: Case 811-b trans problems in reply to Ryan Leasure, 11-29-2004 16:31:26
Hey Ryan: The gear, A22168 is available from CASE. It's a job to get to.
Ryan leasure
11-30-2004 14:17:08
 Re: Case 811-b trans problems in reply to John Saeli, 11-29-2004 17:35:59
The Gear is no longer available through case.
Does anyone know what the # is for the the sleeding sleeve on the range gears is?
Also is there any special way i need to remove the torque convertor from the housing?
Thanks alot
Ryan Leasure
Ryan leasure
11-30-2004 14:15:29
The Gear is no longer available through case. I found a used one in Pa. for $85.20. can be shipped to ohio in 2 days.
Thanks alot
Ryan Leasure
John Saeli
12-01-2004 13:57:15
 Re: Case 811-b trans problems in reply to Ryan leasure, 11-30-2004 14:15:29
Hey Ryan: A11923 is the # for the sleeve. I'd suggest a Service Manual. I had to make a tool to pull the converter.
