PTO ajustment on S standard
George B
08-26-1999 15:41:08
can anyone tell me if there's any adjustment on a live PTO on a '52 S standard??
Jeremy
08-26-1999 16:58:33
 Re: PTO ajustment on S standard in reply to George B, 08-26-1999 15:41:08
The live PTO clutch is adjustable on your model S. Take the cover off the top of the PTO/hydraulic pump housing. This cover is about 3" x 4" and had four 1/2" bolts in it. In there you will find the multiple disc PTO clutch. There are two adjustment pins, one should be pushed in and one will be out. Pull out the "pushed in" pin and then turn the disc pack counterclockwise. Check the engagement lever, it should snap in firmly. Once you have it where you like it, turn the discs until one lock pin will slide back in. The cover bolts torque to 50 ft/lbs. Hope this helps.
