49 case sc magneto?? no spark ..
march
11-27-2004 15:55:55
trying to get the engine started no spark is present at plugs. any tips for trouble shooting ingnition system. not familar with magneto system. tractor has positive ground system if that helps.
John Saeli
11-27-2004 17:13:21
 Re: 49 case sc magneto?? no spark .. in reply to march, 11-27-2004 15:55:55
When was the mag working last? I have seen the ground wire running to the switch grounding itself. Disconnect the wire @ the mag & try it. The mag may also need a good cleaning & setting of the points. The mag is completely independant of the battery.
march
11-28-2004 18:44:46
 Re: 49 case sc magneto?? no spark .. in reply to John Saeli, 11-27-2004 17:13:21
Thanks for the tips John. Just cleaned and adjusted the points, and followed the general knowlage info in the research & info section of this site and off she went.
Glenn F.
11-28-2004 12:12:50
Hey John, it looks like we may be going out east over the holidays. If I get anywhere near your place I'd like to drop by and see you. Where are you located? Up to a little CASE tractor company? Glenn F.
John Saeli
11-29-2004 04:47:50
 Re: 49 case sc magneto?? no spark .. in reply to Glenn F., 11-28-2004 12:12:50
Hey Glenn: We're in Seneca County, in the heart of the Finger Lakes. Just South of Geneva. Be glad to show you around. Keep me posted on your plans. Where are you headed?
