Water Pump Seal for a Case 500
Glenn/Mn
11-27-2004 07:57:02
Need some help just got off the phone with two local dealers they cannot cross or are not interested in doing so, part number 09799AB water pump seal, has anyone done this already through NAPA or someone else, I have exhausted my resources through work I have it out but cannot find any generic numbers on it, nothing wrong with anything else just has been sitting dry for years and the rubbber parts are gone
D Smoker
11-29-2004 17:21:18
 Re: Water Pump Seal for a Case 500 in reply to Glenn/Mn, 11-27-2004 07:57:02
the current number is A166281. Email me if you can't find one.
Steve-MN
11-28-2004 16:23:15
Glenn,
Don L. down in Austin MN rebuilds Case water pumps. You could call him for parts I think.
Good Luck,
Steve
Joe (Wa)
11-27-2004 09:41:29
O9799AB cross-ref nr is A24995 (that may have been changed further to A142499, not sure). That is the same seal as listed for the later 1950's Vac water pump.
Seal may be obsolete as a separate part. The first character in that part nr, the letter O as opposed to the digit 0, seems to confuse some dealers. You're more likely to get the right part by being there in person, rather easy to blow someone off on the phone when crossing nrs gets hard and time consuming.
Joe
