Identify Case tractor with hand clutch and a mag
Tractorcedric
11-26-2004 20:54:58
I found an old Case tractor and the owner is not sure what model it is. It has a hand clutch and a mag.It has the steering rod that sticks out on the left side and way out in front. It has a pressed steel grille in front of the radiator. It has 38 inch tires and is a tricycle. There are parts of another one there but it has a cast iron grille. Thanks
Roger A. NY
11-27-2004 05:07:36
 Re: Identify Case tractor with hand clutch and a m in reply to Tractorcedric, 11-26-2004 20:54:58
Sounds to me like an SC. The tractor with a cast grille should be a DC. Hope this helps!
