Stuck rings on aluminum pistons
L.Lamp
11-25-2004 18:45:24
Does anyone know of a solvent that will loosen stuck piston rings on aluminum pistons? I have a set of good looking pistons for an SC I would like to save and use again.
bigtoed
12-23-2004 20:09:41
 Re: Stuck rings on aluminum pistons in reply to L.Lamp, 11-25-2004 18:45:24
I usually use oven cleaner and throw them in the oven for 30min at 200" or so. make sure they are clean or the wife gets mad
jon (mn)
11-27-2004 19:00:58
if the solvent doesn't work try gently heating the rings with a propane torch. the steal expands at a different rate than the aluminum, breaking them loose. you have to be very careful not to over heat the rings if you want to save them. i have used this metod before and it worked on 3 out of 4 of the pistons.
CNESLER
11-26-2004 13:19:24
Have you tried oven cleaner?
Works well for breaking up carbon deposits
Good Luck
CNESLER
